Hello everyone!
I've been trying to create this form (picture attached) in a conceptual mass family for a few days now, but not been successfull yet. I'm starting to wonder if it is possible to do in Revit at all. I'm new to creating free form shapes and don't know what the possibilities really are.
So far I have tried making a row of plines and created a surface with points that I can stretch to different directions. But the base of the cones don't become round but irregular in shape.
Is there another way to go around with this? I really would appreciate your thoughts on this.
Kristina
Thanks for the quick reply! The slab is an extrusion I suppose, but can it be uneven? Have "waves"?
I edited my sketch, see the attachment.
there is two ways you can create a random surface:
Why do you need such a form ? seems like a student's project.
I've used roofs and toposurface before, adding points. But like you say, it results in a surface consisting of several polygons. Guess the answer to my question is no then, the smoothing has to be done in a different program.
The form is a simplified version of something my boss came up with. I will not tell him about your comment 😄
Thanks!
the better way is to use Conceptual Mass. This allows riplled surfaces....
I've attached a rough screencast showing this.
https://screencast.autodesk.com/Main/Details/2b881318-67c8-4e80-ae5d-e0e3aae599dd
In order to a good understanding of Conceptual Mass applications I recomand you to have a look at Alfredo Medina 's blog
Your Name
Thanks dude, awsome tutorial,
I used to do things like that the "piece by piece" way and it was pretty time consuming.
Thank you very much, Constantin! The screencast was very helpful 🙂 I will check the blog also.
