I am using Revit 2012 and am trying to keep track of where all the groups are used in the project. Instead of clicking through all drawings to check, is there a quick way where I can find such information?
Yes--in the Project Browser, they are listed under Detail and Model Groups.
Not sure if that was the answer you were looking for? It does not show WHERE they are located in the actual model.
You could try selecting a Group, then right click and "select all instances in view or project"?
( Don't have Revit open at the moment and can't recall if that works with Groups.)
I am working on a project with 60+ levels and am trying to track on what levels one specific group is used. I've tried selecting all instances in the entire project by using project browser, but it doesn't tell me what levels the group is on nor how many instances there are...
I do not think it is possible to Schedule Groups, and/or Filter by Level.
However, it IS possible to do so with Assemblies, in RAC 2012 and 2013.
Just a thought......
not a direct answer but it may help.
My colleague, Ron Palma, wrote about this issue here: http://ideatesolutions.blogspot.com/2011/09/searching-for-specific-content-with.html
Model Groups can be sorted by Level, though Detail Groups cannot. After you sort them by level you can double-click on any instance to zoom to the view.
Glynnis Patterson, Architect
www.ideateexplorer.com | www.ideatebimlink.com
Not sure which version you are using, but we can schedule the groups and its reference levels.
Hope this answer your question @Anonymous
Yes, it is possible.
Go the any view such as floor plan, 3d, section, where the group is visible. Select the group and right click > Select All Instances> In Entire Project. Now Simply press 'BX'. It will go to the 3d view with section box. Without clicking anywhere, type 'HI'. It will isolate the selection. You will be able to see all the groups in the entire project.
You can isolate the model groups from the 3D using the 'select similar in the entire project' method.
But if it is an annotation detail group with multiple instances, it is difficult to locate all of them. But in case you are looking to locate a single group- you can select the group from the project browser and it shows the drawing name in properties as seen in the attached snip.
Swapnali G 🙂
