Hello! I have a problem related to toposurface in Revit 2014:
As I know the cloumn bases & tops seem to only attach to roofs, floors & reference planes etc. Can they be attached to toposurface?? I know the column bases can be dragged below the toposuface, but I want the column bases just touch the toposurface. If it cannot doing this, is there other method to do the similar work?
Thanks.
Solved by constantin.stroescu. Go to Solution.
you can not attach it directly to a Toposurface. Anyway this is not as in real life, where you need a foundation for the columns that goes into the terrain...
But , if you want this , I suggest to use a workaround:
Your Name
Sorry for the late reply. Thanks for your advise and I will give it a shot.
