Is there a way to fade linked CAD?
2 REPLIES 2
kwg06516
4066 Views, 2 Replies
Is there a way besides recoloring all the layers in the linked CAD file for tracing?  Otherwise the CAD lines and the project lines have the same weight on the screen.
AutoCAD 2010
AutoCAD 2015
Revit 2015
2 REPLIES 2
CoreyDaun
in reply to: kwg06516
Select the Link in the View, right-click, and go to "Override Graphics in View" » "By Element...". In the following dialog under Projection Lines, you can force the lineweight to a specific value.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
kwg06516
in reply to: CoreyDaun
Thanks.  Changing surface transparency to 50% did the job.
AutoCAD 2010
AutoCAD 2015
Revit 2015
Rail Community
