Is it possible to "purge" a revit drawing??
4 REPLIES 4
chive
16378 Views, 4 Replies
Hi.
Is it possible to "purge" a Revit drawing like you can do in CAD so to make the size of the drawing smaller??
4 REPLIES 4
rimacoca
in reply to: chive
Go to Manage and Purge unused
2420iDC9333C2955AB336
A KUDO is always welcomed; However, when the above answer helps and/or clarifies your query; kindly mark this reply.
Submitted ideas
/ All Revit up dates
Projects BIM Integrated Services
edward_saota
in reply to: chive
It most difinitely is.. go to 'Manage' and click 'Purged Unused'.
Regards
Edward Peinke
LisaDrago
in reply to: chive
Yes - there is a purge option on the manage tab.
are worksets activated in the project? if they are - you may want to compress the file and create a new central file to help with size.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
chive
in reply to: chive
Great....thanks for your help guys Smiley Very Happy
