Is Dell Precision M3800 good for Revit? Scaling issues?
14 REPLIES 14
Message 1 of 15
mrxmry
2518 Views, 14 Replies
I really like Dell Precision M3800 laptop, but reading about the issues with scaling on different softwares are deterring me form that choice.
What is your expreience? I really like that laptop but if it does Revit does not look good on it than I am gonna go for something else. If so, what are the alternatives?
14 REPLIES 14
Message 2 of 15
filipefrancisco
in reply to: mrxmry
Try the HP Workstation Zbook 17, i have one and is fantastic
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
Message 3 of 15
mrxmry
in reply to: filipefrancisco
Hey Francisco, what resolution is your laptop?
Message 4 of 15
KyleB_Autodesk
in reply to: mrxmry
The M3800 is my primary technical laptop (I also have a Surface Pro 3). I have no major issues with scaling or resolution on it. I couldn't ask for a better technical machine, given the build quality and hardware.
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
Message 5 of 15
mrxmry
in reply to: KyleB_Autodesk
Thanks for your input Kyle. Do you have the 15.6” FHD 1920x1080 one? People have been reporting issues with icons being too small and others. Have those been resolved in Revit 2015? Can you comment on other design software: Autocad, Rhino, Sketchup etc What about Adobe CS? Thanks!
Message 6 of 15
KyleB_Autodesk
in reply to: mrxmry
The native panel resolution is insane (3200 x 1800), and I found that adjusting Windows' DPI setting couldn't deliver the desired actual display size of UI elements without moving outside of the "normal bounds" of the DPI spectrum.  So, I can confirm that you'll find some weirdness if you run the max panel resolution + set a high DPI.
I just stepped the resolution to 20148 x 1152, set the DPI to 125%, and have been perfectly happy with it.  I haven't found any major apps to misbehave at 125% DPI.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 7 of 15
mrxmry
Awesome news. Can you post a screenshot of Revit @ 125% on that laptop? Do you think it getting 1920x1080 resolution will be sufficient? Do you see any future benefit to having 3200x1800 screen? Some say there is no real benefit for having high density displays on 15" laptop.
Message 8 of 15
I have 17'' with 1920x1080
Filipe Francisco
YOUTUBE | LINKEDIN
Autodesk Community
Message 9 of 15
KyleB_Autodesk
in reply to: mrxmry
Think that resolution would be fine. I don't find that I need a super-high resolution screen + high OS DPI/ I'm perfectly satisfied with the 2048x1152 + 125% DPI.  My screen cap below.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 10 of 15
mrxmry
Do Adobe applications also look this good?
Message 11 of 15
filipefrancisco
in reply to: mrxmry
It is probably to look good, its enough this resolution
Filipe Francisco
YOUTUBE | LINKEDIN
Autodesk Community
Message 12 of 15
mrxmry
in reply to: mrxmry
I guess I am confused because of the following discussion https://forums.adobe.com/message/7136594#7136594
Message 13 of 15
KyleB_Autodesk
in reply to: mrxmry
That post alludes to exactly what I was referring to as well -> Running the display at native panel resolution, while adjusting the DPI to make things not comically small, results in weirdness across many apps, since many apps are not tested on DPI settings over 150%.  Running at the second highest panel resolution + 125% DPI does the trick for me without any weirdness across major productivity apps.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
Message 14 of 15
mrxmry
Thanks Kyle, your responses are very informative. Now, by no weirdness, do you mean that what you see on the screen is not stretched either? I want to make sure that the images I produce or manipulate will be displayed at other screens with no change in aspect, scale, or quality.
Message 15 of 15
KyleB_Autodesk
in reply to: mrxmry
Yes, the resolution I run matches the aspect ratio of the panel, so WYSIWYG.
-Kyle
Kyle Bernhardt
Director
Autodesk, Inc.
