Hello All!
First time poster, I was just wondering if anyone is able to give me some pointers. I am looking to create an irregular concrete slab, with barrel vaulted ceilings on a small radial section of a circular slab, and a a parabolically curved upper section to the slab, and a large punched hole in the middle of the slab. To this point, I have been able to achieve this using multiple components and masses, but I was wondering if there was a way to make a single object with a single solid material that may be able to achieve the same effect. I have attached a section for ease of explaination.
Thanks in advance for all your help!
Josh
Welcome to the forum.
Was that really the best image you had available? 🙂
Its for a school project, not taken into the construction documentation phase, so it's a fairly rough sketch but it gets the idea across, and, while the curves and edges will be considerable refined, i'm assuming the techniques to obtain the mass will be much the same.
If it helps, the sketch provided is a section cut through the diameter of the circular form.
You can use : Component>Model in Place > Floors
the steps:
Instead of revolve you can use Extrude, or Sweep ....the entity will act as a floor...the walls will attach to it
Your Name
you can see in the attached file an example of such a floor...
Your Name
... I have been able to achieve this using multiple components and masses, ..
Josh
My question about the image refers to your own comment that says that you have already made this form, therefore a 3d view of what you have done would be better to understand the form.
Thank you so much! that worked perfectly!
I do have one last question though, is there any way to limit the rotation of the component or cut a wedge out of the circle?
Thanks a ton for your help!
Sorry for the poor images, the multiple component version didnt work as well as i had hoped, and the form was lost in the mess, but i have attached the version i am working with now using constantin's suggestion.
Select the floor >Edit In Place> select the floor again > look in Properties > Constraints> END ANGLE<>START ANGLE...you can there adjust the segment....Finish Model...
Your Name
