Revit Architecture
Valued Contributor
2 Kudos
Post 1 of 10
IPad 2
2777 Views, 9 Replies
04-05-2011 02:40 PM
Waiting for my new Ipad2 to be delivered. Wondering how I can best use it and Revit 2012 together.
Thad Broom, AIA
61 Kudos
Post 2 of 10
Re: IPad 2
04-05-2011 04:09 PM in reply to: beacharchitect
Have it play music while you are working with Revit from your computer, perhaps?
Valued Contributor
2 Kudos
Post 3 of 10
Re: IPad 2
04-05-2011 05:04 PM in reply to: beacharchitect
I'm hoping i can put together some killer presentations for clients.
Tha A. Broom, AIA
61 Kudos
Post 4 of 10
Re: IPad 2
04-05-2011 05:07 PM in reply to: beacharchitect
Totally.  Have it play background music while you are impressing the clients with your killer presentation.
148 Kudos
Post 5 of 10
Re: IPad 2
04-06-2011 06:17 AM in reply to: beacharchitect
"I'm hoping i can put together some killer presentations for clients."
On an iPad...? Seriously?  April 1st was 5 days ago...
Ross Kirby
BIM Manager
Arcturis
Active Member
0 Kudos
Post 6 of 10
Re: IPad 2
04-06-2011 06:28 AM in reply to: beacharchitect
We've got about half a dozen people using iPad as a presentation, review, markup tool.  With a suitable app it can view various image formats and PDFs.  You can't run Revit on iPad if that's what your thinking.  Autodesk is rumored to be working on a cloud version of Revit (like AutoCAD WS) that could maybe, possibly be used on a mobile device, but that is pure speculation.
651 Kudos
Post 7 of 10
Re: IPad 2
04-06-2011 06:47 AM in reply to: achicksify
New Member
0 Kudos
Post 8 of 10
Re: IPad 2
09-13-2011 07:22 AM in reply to: beacharchitect
We have released an iPad app that you can use to view and markup Revit files. It is called CadFaster and it is available free on the app store. You need a plug-in for Revit to export your models. You can export them as EXEs for Windows users (so they can open Revit files without installing any software) and to the Cloud for iPad users. Everyone who gets access to the model (EXE or cloud) can markup the model and others can see these markup threads in real time. Also, you can arrange co-viewing sessions where one acts as a host and others follow the presentation of the model and markups. Check the app out at
http://itunes.apple.com/us/app/cadfaster/id447057884?mt=8
and download the plug-in at
http://www.cadfaster.com
I am looking forward to your feedback!
Tuomas Holma
Product Support
2 Kudos
Post 9 of 10
Re: IPad 2
09-16-2011 12:01 AM in reply to: beacharchitect
For now, you may check this app for iPhone / iPad on our Labs
http://bluestreak.autodesk.com/Home/Login
Niranjan Kamath
Active Contributor
0 Kudos
Post 10 of 10
Re: IPad 2
12-04-2012 06:12 AM in reply to: beacharchitect
I know this post is a little old, but…
Don’t listen to them tell you your ipad is only good for music. I’ll admit it’s not the most ideal tool for revit, but I use mine in conjunction with revit often.
  1. When I work from home (not at my office with my second monitor attached to my laptop) I use my ipad as second monitor to house the properties and project browser. Actually works well since the touch screen still works, so you can just ‘touch’ the view you want to switch to on the ipad. Mouse also works of course. The graphics processing is a bit slow so it’s not good for your actual drawing, but it works great to clear up the laptop screen from the properties and project browser. I use the app “idisplay” to do this.
  2. “Autodesk 360” works well to access a full set of drawings at a job site. Although it crashes a bit too much. As does keeping pdf's in your ‘dropbox’ and access them anywhere. So the apps you’ll need for this are “autodesk 360” and “dropbox”
  3. And lastly, in a pinch, I have actually used the ipad to draft on. I don’t take my laptop on trips where I don’t expect to be drawing, but if I have to, I use the ipad to access my computer and use Revit remotely. It actually works pretty well, the biggest problem is the lack of a mouse. The app I use has a virtual mouse that makes the use of revit possible. Although not ideal, you can certainly pull up a file, make a few modifications, and send out a drawing in a pinch. I use 'pocket cloud' for this, but logmein works too, just more expensive.
So the ipad isn’t the ultimate Revit tool, but it has its place.
