I cannot seem to find a way to invert a selection in a view. Surely there is a way by now to do such things?
2013 has selection sets, but no, you cannot invert a selection. In what situation would you need to, out of curiosity?
To work with most of the objects instead of a few.
In this instance I wanted to hide everything but some selected objects. I was able to isolate them. That worked here. Most programs allow for inverting a selection so it got me wondering.
Thanks for the response.
Ah, in that case what you'll want to do is Filter the selection. For example, drag a big crossing window around multiple objects to select them, then, in the bottom righ-hand corner of the screen you'll see a little blue funnel (Filter). Select that, and uncheck the items that you don't want to have selected.
I know this is a long time since you posted but I encountered the same problem and have a solution.
You now have a new view with only those items that you want displayed. Yes it would be much simpler if Autodesk incorporated a simple invert selection command. Hope this helps.
1. Select a few elements > Temporary Hide/Isolate > Hide Elements: there you have hid a few and can work with the rest.
2. I know it is a 9 year old thread.
@s.gleeson wrote:
One sometimes needs a view with specific elements and notes/text in them. Using the Filters, as suggested, is very cumbersome as it selects whole groups of elements which one then must go through and deselect all the unwanted elements. Or am I missing something?
Duplicate a view > open the view > select all elements you DO NOT want to hide > Temporary Hide/Isolate > Isolate Elements. Temporary Hide/Isolate again > Apply Hide/Isolate to View.
Seems its incorporated in one of the really good free plugin called pyRevit.
Here it is, Invert Selection.
Thanks ToanDN. That saves a lot of time and now that you have posted it I do remember seeing that option some time when I had no need to use it :-). I did miss something!
After 9 years!! Ingenuous ideas for simple tasks ... Personally IF I would want/need that functionality I prefer Dynamo over all what has been suggested
all these workarounds are ok at best. but come on, an "invert selection" command should be a lot simpler. most other software allow you to tap one key and it knows to invert the whole selection and you can do things a lot faster.
