Hi There,
I have registered at the Autodesk website and I got an email with my serial number and product key.
When I'm asked to fill in this information my product key is considered invalid.
I have already closed the installation file and opened it again but it doesn´t change.
I also have typed many times the numbers and it didn't work.
Thank you in advance for your help.
Solved by thaisa01. Go to Solution.
I an currently having the exact same issue with AutoCAD Revit 2015. I will continue to search for answers and if I find some I will post here.
Okay Here is what I found, unfortunatly for me it just brought me to another page to tell em the serial number in my email is also wrong -_-
But I hope this will be Helpful to you!
Product Key for AutoCAD Revit 2015 Standalone is 829G1
Product Key for AutoCAD Revit 2014 Standalone is 829F1
See these posts for more details and more listings of product codes
Cheers.
Hi There,
Unfortunately that's exactly the Product Key that I've received.
It ticks green when I type the serial number, but it appears a red cross next to the Product key
indicating that's wrong.
I hope I can solve this asap! I really need this program running!
Cheers.
Are you being careful to notice the differences in the naming? There are AutoCAD and Autodesk as well as Building Design Suite versions of the software which each have their own product codes. If you have the serial number to work with, then I'd expect the product code to be on the documentation you received as well. It is odd that you don't have it.
I will refer you to the two links I posted in my previous posts..they have all the product keys. Please check EXACTLY what program you are trying to run because just like the man above me said, it does make a difference. I was actually getting an Email for Revit Extentions with a Code and Key when I needed the Standalone Key and Code. Double check and hopefully this was helpful.
Cheers.
Hi @thaisa01,
I was able to pull up your Student Account and you have downloaded Autodesk Revit 2014. The Product Key for this is 829F1. Try downloading the Product again from our Virtual Agent (Revit Products, Autodesk Revit).
If you're still having issues, please reply back to the post.
Hi Joane,
The Product Key that you gave me it´s exactly the same that Autodesk have provided me by email.
I downloaded the product again from the Virtual Agent and and tried to type the product key again and
it have failured.
What else do you suggest me to do?
Hi!
For some reason I realised that I was downloading Audodesk Revit Architecture when Autodesk only offers the free student version for
Autodesk Revit.
I´ve got the program running now with no problem!
Thank you!
Thanks a lot for the product key of revit 2014, i was getting issues with mine.
@CraftingGamerTom wrote:Okay Here is what I found, unfortunatly for me it just brought me to another page to tell em the serial number in my email is also wrong -_-
Cheers.
