I'm trying to figure out how to assign color to interior walls to individual rooms. For instance, blue for a bedroom, beige for a bathroom, etc. that will show up in 3d views as well as elevations. Any help is appreciated. I am currently using Revit 2012 but will be using 2013 in a couple of months. Thanks
Hi Mike, welcome to the forum.
The way I would paint those walls is to first go into the
"Materials" dialog. Duplicate any of those items and give
it a new name, like "Kitchen wall paint". Then again for the
other rooms. You can choose a color either for just the
graphics appearance or also for the render appearance.
After you get all the room names set up and the colors
chosen for each, close out of that and go to the "Paint"
tool on the ribbon. With the Paint tool you will see a list
of all those items including your new wall paints.
In a 3D view, (make sure you have shaded view selected),
paint the walls.
Please note; if a wall in you model spans across multiple rooms there is an additional step which will be required. You will need to split the face of the wall so the paint is applied ony to the room where you want it rather than the entire wall face.
Here is a link to an article aqnd video showing how split face is used before the paint tool to isilate the area that will be painted.
http://therevitkid.blogspot.com/2012/05/revit-tutorial-logo-painted-cmu-wall.html
And if you DO want "two-tone" walls, you will probably
want some kind of molding where the colors come
together. But then I don't think you said anything
about two-tone walls. Good to know you can do that
though.
Okay I get it. Like of you have a living room that is open to the
dinning room but you want the two rooms to have different
color walls. Then the two different color paints would butt up
against each other. And if no molding then a nice straight
edge for the two colors to come together. And that looks
really good sometimes too.
Edit: "Split Face" tool.
Your example is one possibile situation where splitting the wall need to happen first, but the rooms don't have to be open to one another. I was talking about a more subtle situation where one wall spans across multiple rooms that may need to be a different color and there is an intersecting wall between the 2 rooms. Each room has to have the split face tool used first to get the paint tool to work.
In this case it is not so obvious how this will work. The paint tool does not detect the intersecting wall, so if either of these walls were painted without the split face tool being used first the paint will be applied to ALL rooms.
Hi Loboarch,
Here we can split the walls vertically and horizontally and then paint them. I would like to know , how to paint forms (for instance circle, ellipse...etc) on the same wall?
thanks
Jaf
Hi, im not sure if this would be a solution to your problem, but try adding a workplane to the face of your wall and then add elements to that work plane, this way they will be editable (I believe) in multiple views and they will be snapped to the wall's plane. I use this to create 3D text, trimmings, etc. Regards from South Africa
You can use the Modify > Geometry > Split Face tool to create circles, polygons, or whatever shapes you like.
