Interior Rendering - artificial lights ok, sun disappears
1 REPLY 1
y.ickowicz
1793 Views, 1 Reply
Hi All, wondering if I can have some help with this problem..
Working on an interior rendering, have done it through the cloud previously with no issues.
But now, all of a sudden, the sunlight has disappeared. the artificial lights remain ok, but no sunlight is coming through the windows.
I have tried changing the sunlight settings in the properties panel to every combination I can think of, to no avail.\
Any ideas?
Yoav
edit: images attached
1 REPLY 1
GHASEM_ARIYANI
in reply to: y.ickowicz
hi
in the Render dialog, check the Lighting, For Sunset or day selected <Interior: Sun and Artificial> or For day selected < Interior: Sun only>.
To direct sunlight from outside to inside,Quality Settings List ,Select the Edit option ,In the Render Quality Settings window.
Open the Settings list And a quality selection and then on the choose Copy To Custom.
Now scroll down the drag And the Daylight Portal Options, Choices Windows or Doors and or Curtain Walls the Select .
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Rail Community
