Hi all,
I am working on Floor plan scale of 1:100, i am placing a interior elevation tgs for my Bath room, the tag is bigger than Bathroom size i am not able to see any flooring or other detsil in plan i don't want to change the tag size also. in this case can i move the tag out side of bathroom and show arrow mark as attached drawings.
Please reply me.
Regards
wahid
Solved by ryan.duell. Go to Solution.
For this scenario I have included 3 options:
1. Change the View Scale if possible, to automatically scale the tags.
2. Create an alternative smaller interior elevation tag. Instructions for creating a custom elevation tag are located here.
3. Pull the elevation tags outside the room as you mentioned. You can pull the elevation cut line \ bounding box back in as needed by selecting the view marker and dragging the line back to the previous
Image Example: http://screencast.com/t/fpcmOAhXA
Thank you,
