interface view problem
4 REPLIES 4
ARMK
401 Views, 4 Replies
Hello everyone
As the titel i have a problem with my interface. As additional info, when i say "open new file" or "save file" the windows does not appear. I add and picture of it, is this normal, how can i fix it?
btw, im using a 15" retina macbook pro mid 2014, the model with nvidia g750m, i installed windows 8.1 pro with bootcamp.
Thank You.
4 REPLIES 4
ARMK
in reply to: ARMK
another screen shot
L.Maas
in reply to: ARMK
Difficult to answer that question. Could be installation issues, driver problem, memory problems, windows 8.1 in bootcamp.
But maybe the people from Installation & Licensing forum can help. Maybe the solution is in this POST.
Louis
Please mention Revit version, especially when uploading Revit files.
ARMK
in reply to: L.Maas
thank you that solved my problem,
the "post" section helped me, i played with the display settings from 150% to small, that made everthing very small on my screen but thats acceptable.
now i want to ask another question 🙂 i thought i will see the 3D Wheel on the top right when i fix this but it doesent appear, how can i set it?
L.Maas
in reply to: ARMK
Good it solved the problem.
For your next issue...are you talking about the view cube?
If the view cube (and other view tools) is available depends on the view. The view cube allows to set 3d views. So it will only be available in 3D views.
Further you have your options window (via the big "R" and "Options"). You can then select "viewcube"and you will find all kinds off settings for the viewcube, including Show (On/Off)
Louis
