Hello everyone
As the titel i have a problem with my interface. As additional info, when i say "open new file" or "save file" the windows does not appear. I add and picture of it, is this normal, how can i fix it?
btw, im using a 15" retina macbook pro mid 2014, the model with nvidia g750m, i installed windows 8.1 pro with bootcamp.
Thank You.
Solved by L.Maas. Go to Solution.
Difficult to answer that question. Could be installation issues, driver problem, memory problems, windows 8.1 in bootcamp.
But maybe the people from Installation & Licensing forum can help. Maybe the solution is in this POST.
Louis
Please mention Revit version, especially when uploading Revit files.
Good it solved the problem.
For your next issue...are you talking about the view cube?
If the view cube (and other view tools) is available depends on the view. The view cube allows to set 3d views. So it will only be available in 3D views.
Further you have your options window (via the big "R" and "Options"). You can then select "viewcube"and you will find all kinds off settings for the viewcube, including Show (On/Off)
Louis
