i have a problem with connection of column and wall, i want to insulate a column on exterior surface, and i dont know how to do it? Can You help me?
I attach a screenshot e
If you use an architectural column, the wall finishes will automatically wrap around it. If not, you have to use 2D detailing tools to correct the view. Someone else might have another idea.
Create a new wall including facade board, air gap and insulation. Model it around your column. Adjust base and top level to fit your needs.
