I've created a slab edge like any slab edge, thou many of the slabs I'm placing the edges at has different heights and therefor I need different heights of the slab edges since I wan't them all to merge at the bottom. Using vertical profile offset doesn't cut it, and I don't have time to create 4000 slab edges wth customised heights.
So, is there a way to get instance parameters for these slab edges? What I've heard of the sweep profile family doesn't like instance parameters.. Or if anyone can suggest another solution?
This is really starting to get annoying so any help would be appreciating!
This might help. https://www.linkedin.com/groups/Parameter-not-available-Slab-Edge-68075.S.5900737432239759361
It's definitely a revit glitch.
Just for others who are looking for answers on how to do it, I am just sharing my solution below.
Once you've loaded the parameters to your project, they will not automatically assigned to the slab edges for some reason, perhaps this is a bug on Revit 2015.
Follow these procedures:
1. Go to Manage Tab / Project Parameters
2. Select the parameter that you wish to appear on your slab edge.
3. Click "Modify"
4. Untick "Floors" and the sub-category "Slab Edges"
5. Click "OK" to save the changes
6 Click "Ok" to exit
7. Repeat procedures 1 to 3
8. TICK the boxes "Floors" and the sub-category "Slab Edges"
9. Click "OK" to save the changes
10 Click "Ok" to exit
This bug is still present in version 2017
