I have read solutions for the installation of 2015 and 2016 Revit Content libraries which apparently also apply to 2017 but since the first step is to find 'Autodesk Revit Content Libraries 2017' in your Control Panel's 'Programs and Features' and it does not exist I would ask how do you actually install the Revit 2017 Content?
See snipit below of my 'Programs and Features':
Revit 2017 is installed, as can be seen, but no Content Library!
Any ideas
Solved by Tony_Michniewicz. Go to Solution.
Something did not go ok with the installation I think.
Screenshot from my computer
What I normally do when installing a new version is to completely download (browser download) everything from the server, before installing it.
Content issues seem to be often caused by, that at time of installation, content files are goiing to be downloaded. When than an error occurs you run into these kind of problems.
Maybe you can check your journal files to see if something got reprorted
Louis
Please mention Revit version, especially when uploading Revit files.
If you go for the webinstall, you will always face this problem...Best to download on your PC then install locally.
2017 dlm files can be found on the following two lonks --->> HERE PART 1 and HERE PART 2 (Alternatively; you can download from your account management or Adsk Dsktop App; however, using a different method than webinstall/install now)
Extract them both then run the installation again and install the content library
Had this response from Autodesk:-
Thank you for your recent support inquiry.
As concerns missing libraries you may try to follow these articles:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
But if the libraries are not installed you may download US Imperial and US Metric libraries from this temporary link: https://we.tl/JTBZvoDjJ6
UK library: https://we.tl/mHfNvjSaTk
Belgium library: https://we.tl/j8e5yqow3x
and the please unpack them to these folders
c:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\
c:\ProgramData\Autodesk\RVT 2017\Libraries\US Metric\
c:\ProgramData\Autodesk\RVT 2017\Libraries\UK\
c:\ProgramData\Autodesk\RVT 2017\Libraries\Belgium\
respectively.
Let me know if you need any other country libraries.
Not surprisingly the first two suggestions would not work, since they arrived at the original problem I had pointed identified, however I resorted to the download option and instaled them succesfully. This may be what RDAOU may have been suggesting. The sad thing though is that whilst I am forced to mark this as a solution it isn't really since the installation software should work. Whilst I love the software this 'woolly' ending is typical of Autodesk and their attitude to their software, or it seems to me at least.
Is it possible to have the french version of content Libraries ?
I am downloading the Belgium one but am not sure they are the same.
Unfortunately the download of US and Imperial Content Library does not exist anymore in the first link. We hope referring to anothrt valid link.
regards...
2016 revit türkçe olarak family dosyası istiyorum çok zorlananıyorum malzeme bulmada yardımcı olursanız mail adresinden ulaşırsanız sevinirm. turkey family istiyorum.
yalcin_simsek_57@hotmail.com
We've recently identified a sporadic issue that will result in content not being installed via the Revit LT 2017 web installer. After our investigation, we found that a required content file is not always included in the extracted files and its absence results in the installation bypassing Revit content files. We are investigating the root cause of this problem and hope to have a resolution in place soon. Until then, the following steps will allow you to work around this issue:
At this point, we've only seen this problem occur with the Revit LT 2017 web installer but based on the numerous reports of Revit content installation problems, a similar problem may impact other Revit versions, including previous releases. For this reason, I've attached zip files that contain the master XML files for each version of Revit 2015, 2016, and 2017. Once the appropriate master XML file is extracted and copied to the appropriate ...\Content\Revit folder, the installation of Revit content should complete successfully.
Tony Michniewicz
Autodesk Revit QA
Tony,
I have had the same issue on a number of 2017 updates (LT Suite), for which your workaround works. I have now updated 7 workstations to 2017 and they all have this problem. Why has Autodesk not corrected this since your post on 20th May ?
I now have to do this workaround 7 times - and then have to manually update the templete paths as well.
Is there a faster method to this ?
Dear Andrew Robertson
Can you please attached the US Imperial and US Metric libraries in a new temporary link again, becuase these don´t work anymore
Christian A P
Thanks for the info Tony.
Couldn't workout why all the training video's show templates and families working correctly, I've just spent a 1/2 day researching and fixing this issue for a trail version which only lasts for 30 days.
Not a very good track record to report back to my manager who is deciding which of three products our company will be using, I've been assigned the Autodesk product.
Regards.
Have been trying to figure out this problem for sometime now. These steps worked for Revit 2017. The folder paths and file names were a bit different but replacing the XML files within the Revit 2017\Content\Revit folder worked. Hope this is fixed for future release as I know that R2016 had the same problem.
Hey, Autodesk - if you read this - please, please please look into making things easier for the users who don't have a IT team to deal with fixing these problems.
I have spent the last TWO DAYS going around in circles because these problems exist. And I still haven't resolved my initial issue.
Many thanks.
Hi Tony,
I am having the same issue with Revit LT 2017, but am not having any success with your instructions. I copied the files to the right folder and the US Imperial and Metric now show up under Content Pack in the installer. When I install the content libraries, it all seems to go well, but when I open Revit I still get an error message that the default family template file is invalid.
Because the content pack seems to be installed but not loading, I tried the steps here:
This also didn't help. I seem to be going in circles- any additional help? I have no IT department, just me, and I have no idea what to do next.
Thank you.
the UK path fom we transfer https://www.wetransfer.com/downloads/798ae737d92f6cb1f466c20b0e1b593120160505065313/bed62d
tell me that isn't available anymore.
I really need to have the library and templates of revit 2017
Regards
Walter
The best method -as I see- to fix this problem is to:
1- uninstall "Autodesk Revit Content Libraries 2017" using Microsoft application Tool "MicrosoftFixit.ProgramInstallUninstall" which could be downloaded from Microsoft website. I have been attached it here.
2- Reinstall the "Autodesk Revit 2017". Ensure that "Autodesk Revit Content Libraries 2017" option is checked while keeping your PC connected with the internet. This will take a while but do not disconnect the PC from the internet during this time.
3- When it is finished, you will find that "C:\ProgramData\Autodesk\RVT 2017" folders and their contents are exist with a size of about 2 Gb.
Tony posted further down page with master libraries listed, here's the link Revit 2017 Master XML
