2014/12/9:17:57:28 Ripu MANN-PC === Setup started on MANN-PC by Ripu ===
2014/12/9:17:57:28 Ripu MANN-PC Path_Length: 155
2014/12/9:17:57:28 Ripu MANN-PC Current Directory C:\Autodesk\Autodesk_Revit_2015_English_Win_64bit_R2_wi_en-US
2014/12/9:17:57:28 Ripu MANN-PC Launch
2014/12/9:17:57:28 Ripu MANN-PC Current Directory C:\Users\Ripu\AppData\Local\Temp\_AI2ADA.tmp
2014/12/9:17:57:52 Ripu MANN-PC === Setup ended ===
2014/12/9:17:57:30 Ripu MANN-PC === Setup started on MANN-PC by Ripu ===
2014/12/9:17:57:30 Ripu MANN-PC Path_Length: 155
2014/12/9:17:57:30 Ripu MANN-PC Current Directory C:\Users\Ripu\AppData\Local\Temp\_AI2ADA.tmp
2014/12/9:17:57:30 Ripu MANN-PC Launch
2014/12/9:17:57:52 Ripu MANN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Ripu\AppData\Local\Temp\_AI2ADA.tmp\Setup\RevitSetup.dll
2014/12/9:17:57:52 Ripu MANN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/12/9:17:57:52RipuMANN-PCPageOpenLaunchDialog
2014/12/9:17:57:56 Ripu MANN-PC Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Ripu\AppData\Local\Temp\_AI2ADA.tmp\Setup\RevitSetup.dll
2014/12/9:17:57:56 Ripu MANN-PC Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2015. URLTitle= URLLink=
2014/12/9:17:59:00RipuMANN-PCPageOpenLicenseDialog
2014/12/9:17:59:00RipuMANN-PCPageOpenProductInfoDialog
2014/12/9:17:59:00RipuMANN-PCPageOpenProductSelectionDialog2
2014/12/9:17:59:08RipuMANN-PCPageOpenFullProgressDialog
2014/12/9:17:59:11 Ripu MANN-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2014/12/9:17:59:34RipuMANN-PCInstallMicrosoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161Succeeded
2014/12/9:17:59:36 Ripu MANN-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ripu\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/12/9:17:59:52RipuMANN-PCInstallMicrosoft Visual C++ 2005 Redistributable (x86)Succeeded
2014/12/9:17:59:55 Ripu MANN-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2014/12/9:18:00:18RipuMANN-PCInstallMicrosoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161Succeeded
2014/12/9:18:00:21 Ripu MANN-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/12/9:18:00:24RipuMANN-PCInstallMicrosoft Visual C++ 2012 Redistributable (x86)Succeeded
2014/12/9:18:00:27 Ripu MANN-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/12/9:18:00:28RipuMANN-PCInstallMicrosoft Visual C++ 2012 Redistributable (x64)Succeeded
2014/12/9:18:00:28 Ripu MANN-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:18:00:31RipuMANN-PCInstallMicrosoft Visual C++ 2008 KB958314 (ATL) (x86)Succeeded
2014/12/9:18:00:35 Ripu MANN-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:18:00:43RipuMANN-PCInstallMicrosoft Visual C++ 2008 KB958314 (MFC) (x86)Succeeded
2014/12/9:18:00:47 Ripu MANN-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:18:00:54RipuMANN-PCInstallMicrosoft Visual C++ 2008 KB958314 (CRT) (x86)Succeeded
2014/12/9:18:00:54 Ripu MANN-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:18:01:01RipuMANN-PCInstallMicrosoft Visual C++ 2008 KB958314 (OpenMP) (x86)Succeeded
2014/12/9:18:01:01 Ripu MANN-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:18:01:04RipuMANN-PCInstallMicrosoft Visual C++ 2008 KB958314 (ATL) (x64)Succeeded
2014/12/9:18:01:07 Ripu MANN-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:18:01:16RipuMANN-PCInstallMicrosoft Visual C++ 2008 KB958314 (MFC) (x64)Succeeded
2014/12/9:18:01:17 Ripu MANN-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:18:01:24RipuMANN-PCInstallMicrosoft Visual C++ 2008 KB958314 (CRT) (x64)Succeeded
2014/12/9:18:01:24 Ripu MANN-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:18:01:31RipuMANN-PCInstallMicrosoft Visual C++ 2008 KB958314 (OpenMP) (x64)Succeeded
2014/12/9:18:01:34 Ripu MANN-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ripu\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/12/9:18:01:54RipuMANN-PCInstallMicrosoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)Succeeded
2014/12/9:18:01:54 Ripu MANN-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:18:02:03RipuMANN-PCInstallFaroSDKSucceeded
2014/12/9:18:02:08 Ripu MANN-PC Installing Autodesk® Revit® Content Libraries 2015: TRANSFORMS="C:\Users\Ripu\AppData\Local\Temp\_AI2ADA.tmp\x64\RCL2015\RCL2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:18:07:43RipuMANN-PCInstallAutodesk® Revit® Content Libraries 2015Succeeded
2014/12/9:18:12:08 Ripu MANN-PC Installing Autodesk® Revit® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2015\x64\en-us\RVT2015\RVT2015.mst;C:\Users\Ripu\AppData\Local\Temp\_AI2ADA.tmp\x64\RVT2015\RVT2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:18:13:42RipuMANN-PCInstallAutodesk® Revit® 2015Succeeded
2014/12/9:18:13:49 Ripu MANN-PC Install Autodesk® Revit® 2015 Language Pack Failed Download Failed, Installation aborted, Result=1603
2014/12/9:18:16:41RipuMANN-PCRollbackAutodesk® Revit® 2015Succeeded
2014/12/9:18:17:34RipuMANN-PCRollbackAutodesk® Revit® Content Libraries 2015Succeeded
2014/12/9:18:17:39RipuMANN-PCRollbackFaroSDKSucceeded
2014/12/9:18:17:39 Ripu MANN-PC Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619
2014/12/9:18:17:43RipuMANN-PCRollbackMicrosoft Visual C++ 2008 KB958314 (OpenMP) (x64)Succeeded
2014/12/9:18:17:49RipuMANN-PCRollbackMicrosoft Visual C++ 2008 KB958314 (CRT) (x64)Succeeded
2014/12/9:18:17:54RipuMANN-PCRollbackMicrosoft Visual C++ 2008 KB958314 (MFC) (x64)Succeeded
2014/12/9:18:17:57RipuMANN-PCRollbackMicrosoft Visual C++ 2008 KB958314 (ATL) (x64)Succeeded
2014/12/9:18:18:03RipuMANN-PCRollbackMicrosoft Visual C++ 2008 KB958314 (OpenMP) (x86)Succeeded
2014/12/9:18:18:08RipuMANN-PCRollbackMicrosoft Visual C++ 2008 KB958314 (CRT) (x86)Succeeded
2014/12/9:18:18:13RipuMANN-PCRollbackMicrosoft Visual C++ 2008 KB958314 (MFC) (x86)Succeeded
2014/12/9:18:18:16RipuMANN-PCRollbackMicrosoft Visual C++ 2008 KB958314 (ATL) (x86)Succeeded
2014/12/9:18:18:16 Ripu MANN-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/12/9:18:18:16 Ripu MANN-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/12/9:18:18:16 Ripu MANN-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
I am a Architecture student and was trying to download student version of Revit, that gives three years of free subscription, to do my assignments from home using Revit. And the installation keep on failing.
Above is the "Installation log file" contents.
Please help me asap, as I need to finish my assignment asap.
