Install revit 2014 require 40GB ?
8 REPLIES 8
Message 1 of 9
markxcuf
1144 Views, 8 Replies
I have a issue when I installing the Revit 2014:
Why it needs so large amount of space in system drive (i.e. C:\ )?
post a picture here:   Revit 2014 Install screenshot.PNG
8 REPLIES 8
Message 2 of 9
johnsonsudre
in reply to: markxcuf
I have the same problem....
When I try instalation the Revit 2014 asks 40gb free?
The instalation file have 2,6gb...
What's happening??
Message 3 of 9
olyswen
Not sure why 40gb is required for revit 2014, but your drive is very small and if you can swing it you should do an hard drive upgrade. I just upgrade all four of our computers from 256gb ssd to 512gb ssd. I use a program called paragon migrate os to ssd (only costs $19.95 for software) and it only took be about 1/2 hour to do each computer. You can get a 256gb ssd for under $100 and a 512gb ssd for under $200. The software I mentioned will make a duplicate copy of your old drive and it will be exactly the same when you boot up on the new drive.
Hope you get it figured out.
Jeff
Message 4 of 9
rodrigo.bezerra
in reply to: olyswen
Hi to all
In one of the next screens you can customize the installation content. 40GB is the whole size, but if you select and download only a few family libraries, the amount reduces to less than 5GB.
Regards
Rodrigo Bezerra
Message 5 of 9
johnsonsudre
I can't upgrade my hard disk in this time,
my ssd have 55Gb (total), and have 22Gb free
Anyway thanks for your help!!
Message 6 of 9
Hey Rodrigo, I tried to do this but with a reduction of 1 GB, then the installation is with 39Gb ...
I downloaded the installation instead of installing directly from the Autodesk website, it has 2.6GB.
I still can not understand.
(google translate use: (português > english)
Message 7 of 9
The software is about 2,6GB. The rest is the sum of all libraries. You will
not download all libraries, mostly because they repeat the same families in
imperial or metric systems, in many languages available.
If you customize and install only the software and ONE library that better
suits your needs, you'll dispose of 5GB (tops).
Regards
Rodrigo Bezerra
Message 8 of 9
thanks,
yesterday this not worked, but today worked perfectly!!
[solved]
Message 9 of 9
I'm glad I could help.
Please do not forget to mark my reply as answer.
Regards
Rodrigo Bezerra
