Install requirements 2003/2008 x86/x64
2 REPLIES 2
johnspiral
332 Views, 2 Replies
What are the system requirements to install Autodesk Revit Architecture R11/R12?
Are the installers compatible with any versions of Windows 2003/2008 on x86 & x64 platforms.
If not, are there any workarounds to install and will this impact on the stability of the application?
Background: Our business writes an application that depends on Autodesk Revit Architecture for added features, we install our product on clients machines, various flavors of 2003/2008.
Thanks in advance
John
2 REPLIES 2
LisaDrago
in reply to: johnspiral
You may want to consider posting here...
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
DarrenP
in reply to: LisaDrago
those are server OSes not workstation OSes
what exactly are trying to do?
system requirements: http://usa.autodesk.com/revit-architecture/system-requirements/
DarrenP
