input units: Feet to inches
2 REPLIES 2
MShelp19
1543 Views, 2 Replies
Hi all, When drawing using imperial units in Revit, it of course interprets values you input as feet until you press " to let it know you mean inches. As I am constantly going between Revit and AutoCAD, which does the opposite, I keep missing the " out of habit and wasting time repeating everything. My question is, is there a way to change the input from feet to inches so I can move more seamlessly between the two programs? Thanks, Matt S
2 REPLIES 2
Alfredo_Medina
in reply to: MShelp19
After you configure the units to inches, you won't need to type the quote " for inches. Actually, when you are using feet and inches, you can type 8 6 and that means 8'-6".
For more information on what you need, please visit this other thread: http://forums.autodesk.com/t5/Revit-Architecture/Distance-Input/m-p/4835125#M76188
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
MShelp19
in reply to: Alfredo_Medina
Thank you sir.
