Revit Architecture
Active Member
thisillusionis
Message 1 of 3 (196 Views)
input units: Feet to inches
196 Views, 2 Replies
03-03-2014 04:54 PM
Hi all, When drawing using imperial units in Revit, it of course interprets values you input as feet until you press " to let it know you mean inches. As I am constantly going between Revit and AutoCAD, which does the opposite, I keep missing the " out of habit and wasting time repeating everything. My question is, is there a way to change the input from feet to inches so I can move more seamlessly between the two programs? Thanks, Matt S
After you configure the units to inches, you won't need to type the quote " for inches. Actually, when you are using feet and inches, you can type 8 6 and that means 8'-6".
For more information on what you need, please visit this other thread: http://forums.autodesk.com/t5/Revit-Architecture/Distance-Input/m-p/4835125#M76188
Alfredo_Medina
Message 2 of 3 (188 Views)
Re: input units: Feet to inches
03-03-2014 05:14 PM in reply to: thisillusionis
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Active Member
thisillusionis
Message 3 of 3 (184 Views)
03-03-2014 05:23 PM in reply to: Alfredo_Medina
Thank you sir.
