Revit Architecture
Revit Architecture
Valued Mentor
9 Kudos
Post 1 of 24
Inches to the fourth power!
6550 Views, 23 Replies
06-21-2012 12:11 PM
Can anyone explain why, when I try an open a project file that was previously worked on and saved without incident, should produce a dialog box with the statement 'Inches to the fourth power' having only a 'close' button which after clicked sees no further action in opening the project?  I would point out that I work in metric and the project units on this file are set to the nearest 10mm.
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
One user in another forum commented that he had seen this error message, and that the reason for it was insufficient disk space in the server to open that file. I hope it helps.
Valued Mentor
40 Kudos
Post 2 of 24
Re: Inches to the fourth power!
06-21-2012 05:26 PM in reply to: IMCornish
 'Inches to the fourth power' sounds like square inch to me.
Distinguished Contributor
11 Kudos
Post 3 of 24
06-21-2012 09:00 PM in reply to: vector2
Revit revealing it's imperial heritage?
http://thebuildingcoder.typepad.com/blog/2011/03/internal-imperial-units.html
So sad they started with a measurement system most of the world has abandoned!
Valued Mentor
40 Kudos
Post 4 of 24
06-21-2012 09:31 PM in reply to: robincapperw
It's a measurement system used in the USA. Revit was born in the USA
so that's the primary measurement system it uses. But Revit can also
use measurement systems native to other countries. And it's not that
difficult to translate measurements and languages from one country to
another.
Valued Mentor
9 Kudos
Post 5 of 24
06-22-2012 02:34 AM in reply to: vector2
Well thanks chaps!  I did not think that I was going to start a discussion about imperial versus metric measurement.  In case you missed it, the crux of my problem is that I cannot open the project.  Secondry is why I should get this cryptic message.  Any ideas please.
Andrew Robertson
Chartered Architect
Truro. UK
363 Kudos
Post 6 of 24
06-22-2012 03:14 AM in reply to: IMCornish
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Employee
58 Kudos
Post 7 of 24
06-22-2012 06:55 AM in reply to: IMCornish
You may have a corrupt file.  Does the file size seem reasonable?
You don't say if the file is workshared and if more than one person is seeing this error, but you could try opening it detached from central and auditing it.
If that doesn't work, you should contact support and see if they can help you open it.
Joe
Valued Mentor
9 Kudos
Post 8 of 24
06-25-2012 08:59 AM in reply to: Alfredo_Medina
I think that you must be right Alfredo.  I opened it with ease on a workstation so can only think that my laptop needs a little more memory.  thanks for you help.
I would still be interested why this message should be generated.  Is there a published guide to the dialogues that Revit might produce, perhaps the programme developers?
Andrew Robertson
Chartered Architect
Truro. UK
363 Kudos
Post 9 of 24
06-26-2012 04:14 AM in reply to: IMCornish
I have not seen a list of error messages and their meaning. This error message is very strange, but at least now we now that it is caused by insufficient disk space.
Employee
110 Kudos
Post 10 of 24
06-26-2012 05:04 AM in reply to: IMCornish
There is not any kind of published guide to all of the possible error messages that Revit can produce.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
