Welcome to Autodeskā€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forĀ
Did you mean:Ā
Inches to the fourth power error
5 REPLIES 5
restender2000
857 Views, 5 Replies
Inches to the fourth power error:
PLTW CEA student saved a habitat project.  He is unable to open the file and gets an inched to the fourth prompt when trying to open the file.
5 REPLIES 5
CoreyDaun
in reply to: restender2000
Hello, welcome to the Discussion Groups!
Typically, this enigmatic error indicates that there is insufficient disk space.
ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€
āž|āž Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
restender2000
in reply to: CoreyDaun
With the insignificant disc space-if disc space is cleared up, will the file open.
Or, will the student need to clear up disc space and then restart?
Rachel Stender, P.E. (inactive) MBA
Engineering Department Head
Walt Whitman High School
7100 Whittier Blvd.
Bethesda MD, 20817
301-320-6607
CoreyDaun
I've not encountered this error myself so I am uncertain, but I imagine he would be able to open it without restarting. If the problem persists, try restarting it then. If you have any more trouble with this error, search this board for the term "Fourth Power" and there should be some additional information that pops up from previous threads.
I have encountered this same issue. However I have tried copying the file to my desktop and with 110GB of free space I am still unable to open this 28MB file. Any ideas?
Have you had this problem with other files of comparable size? If not, you may have a corrupt file, as suggested as a possibility in this thread so I would suggest opening a Support Case with Autodesk Support, if you are on subscription.
Rail Community
