I have a datalogger that can send information to a PC via a serial port and TCP/IP.
Can I use the input from the data-logger to update a parameter in Revit in real time?
For ex: The color of the wall, or the light intensity in the room, for real-time rendering of actual building, this input can be useful, this can also be useful for doing sun-light related optimisation etc. etc.
Dear @chintanp ,
Do you want the Datalogger data to the Revit Model or to the sensors attached in Revit model (Integrations with IFC) such that when the model is executed and get functional then that will grab the data from the data logger to work with softcomputing in some server for IoT in functional structure?
