Did you open the visibilty/graphic override window, place a check mark in
the "Show catagories from all disciplines", and then turn on all the
visibilty settings?
wrote in message news:5920228@discussion.autodesk.com...
I'm trying to import the Revit model generated by my Mechanical consultant
(generated in Revit MEP) into my Revit Architecture 2008 file. I import
through the normal channels and see nothing in 2D/3D. My views are set to
coordination and everything is on in visibility graphics.
In the past I had a work around of opening MEPs model and changing the
discipline to Architecture. That no longer seems to be an option.
Any help here would be appreciated. Thanks.
-Ian
