I am use to standard autodesk insert drawing. How do you bring a Revit drawing into a Revit drawing
The inserted drawing seems to be a block, or one object. Can I make the wall and other items separate?
Link Revit is something similar to External Reference from Autocad. The linked entity acts like a block but you can anytime open the original file , make changes and then reload it.
If you select the linked file , under Link there are two options : Bind Link and Manage Links
Constantin Stroescu
