How much work do you want to do?
If you are willing to take a few steps, install some software, keep
reading. Otherwise, disregard this message.
First, install Bentley's DGN viewer. Available as a free download from
their website (www.bentley.com)
Open the file and print to PDF.
You can use Ghostscript/Ghostview/pstoedit to convert PDF files
Download Ghostscript, GhostView and pstoedit all available here.
(http://www.cs.wisc.edu/~ghost/gsview/) Follow the directions for
installation for each program.
Then in GhostView open the PDF and convert it to DXF
(http://www.stillhq.com/ctpfaq/2002/03/c727.html#AEN914)
HTH
John Gray wrote:
> Is it possible to import Microstation V8 files into Revit Building 8.1? At
> first glance it is not possible. The option of saving back or working in
> DWG mode in microstaion is not an option unfortuently.
> Thanks,
> John Gray
