Revit Architecture
*Andy Smith
Post 1 of 3
Importing .dxf and .dwg
61 Views, 2 Replies
05-05-2005 01:52 PM
I am trying to import section and detail drawings onto my output sheets but
am coming up with weird scaling. What is the trick to bringing these
drawings in at normal scales?
asmith
Re: Importing .dxf and .dwg
05-05-2005 10:35 PM in reply to: *Andy Smith
From the import dialog use the correct units (bottom left)
Active Member
0 Kudos
Post 3 of 3
05-05-2005 11:22 PM in reply to: *Andy Smith
You can also change the scale after you've imported the file by selecting it and going to its properties then changing its import scale.
HTH.
Post to the Community
New Post
