Importing CAD files to Trial Version of Revit
5 REPLIES 5
693 Views, 5 Replies
I have downloaded the trial version of Revit and am having some difficulty in importing my CAD files to Revit.  When I select the 'Import CAD' button it doesn't allow me to select any files from my Computer - when I click 'Desktop' I am advised that there are no CAD files located there even though I just saved one to my desktop.  I should note I am using AutoCAD 2013.
Thanks in advance for your help! Smiley Happy
5 REPLIES 5
LisaDrago
Hello and Welcome to the Discussion!
So a trial version is the full version of but only viable for 30 days...
The first thing I would look at is the file type - what is the file type set to?
I know it may be a no brainier - but it is the first place I would look.
What type of file are you trying to bring in and what type of file type is it looking for?
 LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
in reply to: LisaDrago
Having the same problem with the trial version not seeing dwg files.
DarrenP
which trial did you use:
Online trial
  • Start using in minutes
  • No software to install – just the player  (1.4MB)
  • Access, save, and retrieve files through Autodesk® 360 cloud-based workspace
  • Same features as download version, with the exception of worksharing collaboration
  • Accessible from virtually any web-connected computer
Online Trial Overview
START NOW
Desktop trial
  • Download and install directly on your desktop
  • Full use of Revit
if you used the online trial you can only use files that are uploaded to your Autodesk 360 account
DarrenP
in reply to: DarrenP
You are exactly right, I was using the online version. Thank you for your
help. That was driving me crazy.
This was the issue... had the online trial.  Thank you!
