Importing a file from Archicad in to Rivet.
1 REPLY 1
sasds
501 Views, 1 Reply
I am trying to import a file from Archicad in to Rivet.  Is I possible?
1 REPLY 1
loboarch
in reply to: sasds
You might try exporting to IFC from ArchiCAD and then importing the IFC file into Revit.  You will probably have manual cleanup type work you need to do however.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
