Importing a Drawing created in Fabrication into Revit
0 REPLIES 0
Message 1 of 1
jmiller-CDES
236 Views, 0 Replies
Have a client that did the Mechanical work in Autodesk Fabrication and sent the dwg created from it. I not sure of the process they used to create the dwg. I am using Revit Arch 2012 to link the dwg. I do not get any errors, but the dwg does not come in the correct location and only a very small corner of the Model is shown and not everything in that area is shown. I have seen the add on for imprting a Fabrication to Revit, but the client says it is not working for them. What is the best way to import a file from Fabrication into Revit? Or, why does the dwg link not work correctly? Thanks for any help that I can get.
0 REPLIES 0
