Which is a better solution in terms of not losing any of the geometry of the model from Tekla to Revit?
Directly export Tekla file to Revit file using the "Export to Revit" application inside Tekla software?
Or directly export Tekla file to IFC file format?
I found the following FAQ for Tekla Revit interoperability:
http://www.tekla.com/international/solutions/building-construction/Pages/tekla-revit-questions-and-a...
Question 4 has information relevant to your question:
4. What is the file format used in this linking?
The users will have Export to Tekla and Export to Revit buttons available in respective software to create exchange files. The data transfer is based on the IFC format but will be extended beyond the IFCs. The IFC format is the common ground for this but not a limitation.
From the answer above, it sounds like the Tekla export option will output more information than IFC would.
404 Not Found from the link you sent Lance, I wonder what it used to say?
"4. What is the file format used in this linking?
The users will have Export to Tekla and Export to Revit buttons available in respective software to create exchange files. The data transfer is based on the IFC format but will be extended beyond the IFCs. The IFC format is the common ground for this but not a limitation."
They seem to have a tool for that
Please do u have links to download integration tools between tekla structure , revit , and navisworks
I don’t know how accurate this information is now, but I am attaching the text of the question and answer page (courtesy of the Internet Archive).
https://www.youtube.com/watch?v=65EIaXT0jYk
