I have a problem importing a dwf file from Autodesk Design Review to Autodesk Revit Structure. I've tried copying it and other ideas without a good result. Please help.
You ahve tried the insert dwf? image below...
what issues are you having?
LD
We got a .dwf file with a drawwork, and we want to insert it in Revit Structure, but we cant figur out how...
What to do?
Can you convert it to a tif jpeg, png, jpg, bmp? Then you would be able to pull it in as an image.
If you can get the dwg - that woul dbe even better.
LD
I cant figur out how to save it as a png. dwg.. when i click save as the only option is dwf file or .dwfx file...
