You can also import it in AutoCAD and then Import-link it to Revit the Excel spreadsheet or using a screen capture program capture the spreadsheet as a JPG and import the image into Revit.
The first method allows you to update the spreadsheet in Excel, then update it in AutoCAD and finally it will update in Revit.
Mel Persin, aia
Mel Persin, aia
