can you import 3d DWG lines from Rhino into Revit to use them so I can sketch over the lines and create new lines / data for sweep?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Yes, but...
I don't know if you can do it with Revit itself, because I haven't found a way to align a workplane to the imported 3d line.
It's easy to do it through Dynamo though. The method below will give you a set of model lines which you can use to create your sweep (or create a sweep in Dynamo :))
Claas Kuhnen
Claas Kuhnen
You can download it from here http://dynamobim.org/ (the site is under maintenance today, but download still works)
Have a look at Zach Kron's blog - http://buildz.blogspot.com.au/ for some more information. Or here here or here
Claas Kuhnen
When I try to use the method described above on a closed NURBS curve it comes in as two curves. Is there a way to join these back together into one closed NURBS curve? I'm trying to create a NURBS floor which currently isn't possible natively within Revit.
Claas Kuhnen
I know how to join curves in rhino. Its Dynamo thats the problem. It automatically splits a closed curve
