import 3d DWG for sweep in Revit
10 REPLIES 10
Message 1 of 11
cekuhnen
1564 Views, 10 Replies
can you import 3d DWG lines from Rhino into Revit to use them so I can sketch over the lines and create new lines / data for sweep?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
10 REPLIES 10
Message 2 of 11
maciejwypych
in reply to: cekuhnen
Yes, but...
I don't know if you can do it with Revit itself, because I haven't found a way to align a workplane to the imported 3d line.
It's easy to do it through Dynamo though. The method below will give you a set of model lines which you can use to create your sweep (or create a sweep in Dynamo :))
Message 3 of 11
cekuhnen
Sorry for asking what system is that k in the screen shot?
Claas Kuhnen
Message 4 of 11
maciejwypych
I'm not sure what you are asking? What k? You mean the imported 3d spline?
Message 5 of 11
cekuhnen
in reply to: maciejwypych
grrr typo, I was curious what interface you show in you screenshot. is that Revit?
Claas Kuhnen
Message 6 of 11
maciejwypych
You can download it from here http://dynamobim.org/ (the site is under maintenance today, but download still works)
Have a look at Zach Kron's blog - http://buildz.blogspot.com.au/ for some more information. Or here here or  here
Message 7 of 11
cekuhnen
Cool a Grasshopper like interface for Revit!
Claas Kuhnen
Message 8 of 11
maciejwypych
I can't imagine modelling something in Revit more complicated than a box without Dynamo 🙂
OK, maybe I'm exaggerating a bit, but it definitely helps to have this tool.
Message 9 of 11
winston1980
When I try to use the method described above on a closed NURBS curve it comes in as two curves. Is there a way to join these back together into one closed NURBS curve? I'm trying to create a NURBS floor which currently isn't possible natively within Revit.
Message 10 of 11
cekuhnen
in reply to: winston1980
Sure rhino can join surfaces with the join command. Do you have rhino? Need
help?
Claas Kuhnen
Message 11 of 11
winston1980
I know how to join curves in rhino. Its Dynamo thats the problem. It automatically splits a closed curve
