Revit Architecture 2008 Imperial Tutorials and Datasets
The imperial tutorials and datasets are now available on the Autodesk website. Follow the instructions below to download the tutorial exercises and datasets to your computer.
Tutorial Download Instructions:
Navigate to: C:\Program Files\Revit Architecture 2008\Program.
Right-click each tutorial CHM file, click Properties, clear the Read-only attribute, and then click OK.
Click the following link to access the Autodesk Revit Architecture 2008 Documentation download page. http://www.autodesk.com/revitbuilding-documentation-enu
Under Select a language, select your language.
On the Autodesk Revit Architecture 2008 page, under Tutorials, double-click the Revit Architecture Imperial Tutorial EXE file.
In the File Download dialog, click Save to save the file to your Desktop.
On your Desktop, double-click the EXE file that you downloaded to automatically extract the file to the correct folder on your local computer.
Note: After the download is complete, the imperial tutorials will be available by clicking Help menu -> Tutorials.
Dataset Download instructions:
On the Autodesk Revit Architecture 2008 page, under Imperial Datasets, double-click the first Revit Architecture Dataset EXE file.
On your Desktop, double-click the EXE file that you downloaded to automatically extract the datasets to the correct folders on your local computer.
Using the same method, extract the remaining dataset EXE files on the page.
Note: Once the downloads are complete, all datasets will be available in the Training folder within Revit Architecture 2008.
