I have been testing the new IFC4 Exporter. If I export in IFC4 format, and then attempt to open/import the resulting IFC file in Revit 2014, the results contain none of the original building elements. It seems to be a part default template. If I export in IFC2x3, then re-open as before, the results appear correct.
Is it the case that Revit 2014 UR1 and the new IFC Exporter (3.6.0) only deals with the Export of IFC4 and not the Import?
Regards, Dale
______________
Yes, I'm Satoshi.
