IFC XML
4 REPLIES 4
veguru
3545 Views, 4 Replies
IFC XML
Hi ,
I was wondering if Revit supports IFC XML.
coz when i exported my revit model to IFC it exported as IFC (2x3), but it not give me an option for exporting it as a IFCXML .
It would be great if any one can point me they way to do that.
Thank you in advance,
Sundeep
4 REPLIES 4
ryan.duell
in reply to: veguru
Currently there is no option for IFC XML.  You can however export to GBXML.
I have included the Help Documentation Options below:
http://docs.autodesk.com/REVIT/2011/ENU/filesUsersGuide/WS1a9193826455f5ff1d61fe411049ed455e-752f.ht...
I have included 2 related posts on IFC below:
http://revitoped.blogspot.com/2010/04/i-speak-ifc.html
http://redbolts.com/blog/post/2010/05/20/IFC-has-no-place-in-your-Revit-BIM-workflow.aspx
Thank you,
Ryan Duell
Tags (3)
veguru
in reply to: veguru
HI Ryan ,
Thank you, I will go through the material.
-S
suatnasif
in reply to: veguru
Hi, I was wondering if there is any manipulations on revit to establish an interface to give outputs into MATLAB Simulink?
Regards
alan.quinn
in reply to: suatnasif
Perhaps via API. Go here for more information. http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=6364883
