I have never had any issues with exporting IFC's from Revit up until now. IFC coordination is a huge part of our workflow in our office and now we have hit a brick wall with this random error that came out of no where. I don't know what changed in the model to have introduced this error.
When I go to export an IFC from our Revit file, no matter settings I have set, the export terminates with the below written error message:
"There has been an unrecoverable error during export. Export will now be aborted."
I took a screen shot of this error and attached it as well. It has no identifiable errors attached to it and no explanation whatsoever for the failure.
I have audited our model and removed links to see if they were causing problems to no avail. I also have installed the most up to date IFC exporters from Autodesk's website. Also no effect.
Please, we need assistance with this ASAP.
I'm having the same issue with two files that were working fine for a long time. Now they just fail with no information. Is there no answer to this major issue? How do I determine which model element is causing the application to close?
