Hey guys,
I'm trying to export my model to IFC including all of my projectparameters.
The last part seems trickier than I thought.
I have some sharedparameters which were added through projectparameters, added that to some categories. So far so good.
IFC export.
Loading the ifc file and I notice none of my custom projectparameters are exportered.
Example:
shared parameter "wallclamb" is loaded and assigned to walls.
IFC export doesn't have the 'wallclamb' parameter.
Next step I did: fill the "wallclamb" with a value "no need", next step: empty the field again. Export: voilà: the parameter "wallclamb" is exportered and has value "" aka. empty.
My question: how do I export my projectparameters WITHOUT population the fields first?
May be IFC Exporter can help you.
2013:
IFC Exporter for Revit 2013 (v2.16):
IFC Export Alternate UI for Revit 2013 (v1.16):
2014:
IFC Exporter for Revit 2014 (v3.8):
IFC Export Alternate UI for Revit 2014 (v2.8):
