Revit Architecture
Distinguished Contributor
kate_vanhout
Message 1 of 3 (185 Views)
if parameter
185 Views, 2 Replies
06-12-2013 02:01 PM
I am using Revit 2013 and I am trying to create a text parameter for my windows that will tell you what grid is installed in the window according to which grids you choose (from my parameters above) I have included a picture to better show what I am trying to do.  Is there a way of doing this!?  So far the parameters i have tried to use dont seem to work...
Please see my reply to a similar question, at the bottom of the page, at:
http://forums.autodesk.com/t5/Autodesk-Revit-MEP/IF-THEN-Formula-and-Yes-No-Parameter/m-p/3818889#M18750
Kate,
to elaborate on Alfredo's answer:
Good Luck!
Alfredo_Medina
Message 2 of 3 (160 Views)
Re: if parameter
06-12-2013 03:46 PM in reply to: kate_vanhout
http://forums.autodesk.com/t5/Autodesk-Revit-MEP/IF-THEN-Formula-and-Yes-No-Parameter/m-p/3818889#M1...
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Member
autodesk
Message 3 of 3 (135 Views)
Re: if parameter
06-13-2013 02:34 AM in reply to: kate_vanhout
Kate,
Good Luck!
Grtz, RB.
