if parameter
2 REPLIES 2
kate_vanhout
356 Views, 2 Replies
if parameter
I am using Revit 2013 and I am trying to create a text parameter for my windows that will tell you what grid is installed in the window according to which grids you choose (from my parameters above) I have included a picture to better show what I am trying to do.  Is there a way of doing this!?  So far the parameters i have tried to use dont seem to work...
2 REPLIES 2
Please see my reply to a similar question, at the bottom of the page, at:
http://forums.autodesk.com/t5/Autodesk-Revit-MEP/IF-THEN-Formula-and-Yes-No-Parameter/m-p/3818889#M1...
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
autodesk
in reply to: kate_vanhout
Kate,
to elaborate on Alfredo's answer:
Good Luck!
Grtz, RB.
