I am using Revit 2013 and I am trying to create a text parameter for my windows that will tell you what grid is installed in the window according to which grids you choose (from my parameters above) I have included a picture to better show what I am trying to do. Is there a way of doing this!? So far the parameters i have tried to use dont seem to work...
Solved by autodesk. Go to Solution.
Solved by Alfredo_Medina. Go to Solution.
Please see my reply to a similar question, at the bottom of the page, at:
