Hi all,
I am trying to produce a wall types plan, on which I can tag the wall type easily enough, but in certain instances it is critical to know what 'side' of the wall is which end. By that I mean where I have a bedroom against a bathroom I want to highlight where the waterproof layer is and on the other side in the bedroom where the plasterboard side is (this is harder to explain than I realised). The eexample of the bathroom and bedroom is actually pretty obvious which way around the wal l should be however there are other instances whereby it is a lot more subjective so the ability to identify the 'faces' if you like would be ideal.
Has anyone got around this in a nifty way?
Many thanks
in the wall assembly it shows you what is the exterior side and interior side - image attached. so when you build your wall layers - you need to keep them in order.
when you place a wall - the side with the flip arrows is always the exterior side. also image attached.
LD
