I NEED YOUR URGENT HELP please :'''(
5 REPLIES 5
meem.almehairy
230 Views, 5 Replies
I was working in the revit class and all of a sudden fatal error massege appeared
and the program is not opening anymore, when i open it it keeps syncing forever Sad
I uninstalled it and reinstall it again and still it doesn't open :''''''(
i attached a capture of what it shows me
blank page and the cursor shows the syncing symbol and thats all :'(
please HELP me I have to submit my assignment tommorow and i didn't start yet i am running out of time
5 REPLIES 5
enslinj
in reply to: meem.almehairy
Hi There,
Two things I would suggest you try.
Since Revit doesn’t run on MAC natively, try opening it on a PC & seen if the same thing happens.
On both your MAC & PC the second thing you can try is, open Revit, browse to the file & highlight it.
If it is a central file, check the tick boxes named "Audit" & Detach from Central" before clicking open.
See if this helps you out.
Regards
meem.almehairy
in reply to: enslinj
Thank you for your reply
but i have the windows downloaded in my mac, and I downloaded the revit from the windows, as mentioned previously it was working perfectly before the error 😞
Sorry I didn't understand the second point. From where can I find (Audit)?
meem.almehairy
If I have to choose the "audit" thing from the program itself, I can't because it is not responding AT ALL Man Sad
enslinj
I wasn’t sure if it’s a program or project specific problem.
I don’t have much experience with dual booting or parallels for running Windows on Mac. However, I have never encountered something like that on PC  which leads me to believe the problem most likely lies with the operating system & your dual boot environment & not Revit per say.
Perhaps somebody with more experience on the matter can advise you. My gut feel is this is more IT related than Revit.
meem.almehairy
Thank you for your reply, I will check with them ASAP
I am just wondering, if there is a shortage in the memory of windows in my mac would that affect the program?
Thank you
Rail Community
