I need to draw a simple family for a life safety plan
2 REPLIES 2
rlabib
1699 Views, 2 Replies
I need to draw a very simple family as shown in attached picture , that has only two parameters (EXIST and EXIST ) , can anyone tell what family should I start with?
2 REPLIES 2
CoreyDaun
in reply to: rlabib
I believe that this would best be accomplished with two separate Line-Based Detail Item families. You could then create a schedule to report the distances and Exit #. You could use the Comments parameter to enter a designation value so that each instance of this report can be separated (filtered by the schedule) and thus have it's own schedule.
Here is a related thread with more info on how to accomplish this:
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Drawing-exit-path-from-rooms-to-exit-door/...
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
loboarch
in reply to: rlabib
Here is an article from Revit wikihelp that covers this topic.
http://wikihelp.autodesk.com/Revit/enu/Community/Examples/Two_Pick_Family_to_Calculate_Fire_Exit_Dis...
Jeff Hanson
Principal Content Experience Designer
Revit Help |
