We've seen this a few times on our Tech Support. I believe you'll need to
open your local copy of "Roberts Forebay BARN..." and Save to Central, then
relinquish everything. Next, when you reopen the main file (where you're
getting the message) the problem should be fixed if you reload the file.
This situation arises when you link in another workset enabled file. It's
letting you know that the linked file is not necessarily completely
synchronized (something is borrowed or checked out).
Let me know if that works.
Glynnis Patterson
www.ideateinc.com/educate/online/revit201
wrote in message news:5785469@discussion.autodesk.com...
Linking in a barn into my main house model and getting this message every
time I save? Not sure what I need to do to fix it so it doesn't keep poping
up.
